How to solve Warning_duplicate_row?
  • Nov 14, 2019 8:01 AM UTC
  • 342 views
 During my usage of AIMMS, I came up with some problems about 'duplicate_column_row_warnings'. I want to know how to solve the following questions:
(1)Warning: The rows "MaxPump(PSHU-2Pump,01,Unit-1)" and "MinPump(PSHU-2Pump,01,Unit-1)" are equal in the generated mathematical program "LeastTotalcost".  For information regarding potential causes and consequences, see the help associated with the option "Warning_duplicate_row".
I wonder what does this mean?
(2)where can I find the help associated with the option "Warning_duplicate_row"?
Best answer by Chris Kuip
Hello Sunxinye,
Let me first answer the second question:
The AIMMS engine provides many options that tailor its behavior.
Other packages call such options, settings or preferences.
You can change these options via the AIMMS Menu - Settings - Project options... dialog.
In the lower-left corner of the dialog that appears you can search for a setting.
Just fill in "Warning_duplicate_row" and it will find the setting of that option.
There is also a Help button available that will lead you to information about the option "Warning_duplicate_row".
Now to your first question:
You may want to check a constraint listing for the rows at hand.
See the option "constraint_listing" ;-)
With kind regards,
Chris
Chris Kuip
  • Nov 15, 2019 7:52 AM UTC
Hello Sunxinye,
With kind regards,
Chris
  • Newcomer
  • Nov 15, 2019 8:14 AM UTC
Dear Chris,
Thank you for your help!I will try my best to find this solutions!
