How to write a constraint with format variable smaller equal to parameter?
  • November 28, 2024
  • 57 views
I am a beginner at using AIMMS and have my sets, parameters and variables all sorted out. I am, however, stuck with one constraint. I have a variable x(p) (so x(p) needed) and parameter d(p) (max capacity (p)) and want to have a constraint x(p) <= d(p), but without havin to use a sum. How do I so this? Thank you.
Best answer by gabiservidone
Hi! Exacly as you wrote, and you just need to add ‘p’ as an index domain of your contraint:
This two courses will help you creating your first model!
  • November 28, 2024
