how to write a definition of variable
  • Mar 12, 2020 1:49 PM UTC
  • 207 views
Dear all
I have two variables: X and Y with index domain t.
I want to write in definition of X such as
X[0] = 0.3
X[1] = X[0] + Y[1]
X[2] = X[1] + Y[2]
How do I write in definition part of variable X ? Please help me
Thank you so much
Best answer by mateusarakawa
I would try:
0.3 $ (Ord(t) = 1)
x(t-1) + y(t) $ (Ord(t) > 1)
mateusarakawa
  • Mar 12, 2020 5:24 PM UTC
I would try:
0.3 $ (Ord(t) = 1)
  • Newcomer
  • Mar 13, 2020 12:12 AM UTC
It is very helpful. Thank you very much, @mateusarakawa
  • Mar 13, 2020 2:29 AM UTC
@Huy , as your condition is dependent on the index domain and not on a variable, you could also use an if block in the definition of variable x(t).
if ord(t) = 1 then
0.3
else
x(t-1) + y(t)
endif
This will generate the below constraints - assuming that the elements in set T are {0,1,2,3,...}
x(0) = 0.3
x(1) = x(0) + y(1)
x(2) = x(1) + y(2)
  • Newcomer
  • Mar 13, 2020 2:56 AM UTC
this command is easy to understand and useful. Thank you a lot @mohansx
