Index domain with certain indices without mentioning separate set
  • Apr 4, 2024 5:49 AM UTC
  • 93 views
I am trying to write a constraint with index domain on certain indices
vBinary1('1') + vBinary1('3') + vBinary1('5') = 3 * vBinary2;
‘h’ is the index. Here ‘h’ is taking value {‘1’, ‘3’, ‘5’}. Do not consider it as ODD.
I tried with
index domain: | h in {"1", "3", "5"}
sum[h, vBinary1(h)] = 3 * vBinary2;
It is giving errors by saying
The scope of index "h" has not been specified. Help to understand it.
Do not define another set for these indices only. That I know how to do it.
Best answer by gdiepen
Not sure what you want to achieve.
You want to write the constraint using a sum without defining another set for just these indices? Isn’t it just easier to write the original line you had?
Otherwise it will be just a bit more complex, something like:
sum( h | (h = ‘1’) or (h=’3’) or (h=’5’) , vBinary1(h) ) = 3*vBinary2
  • Apr 4, 2024 6:33 AM UTC
