Interrupt Solver
  • Jun 7, 2021 4:32 AM UTC
  • 148 views
Is it possible to limit the solver session of multi objective optimization for a specific time?
@vishweshpatil To limit the (cumulative) solving time of the entire multi-objective solve you can use the Solvers General option ‘Time Limit’.
If you want to limit each of the optimization problems solved during the solving process of a multi-objective optimization problem, you should use parameters files and enable the CPLEX or Gurobi option ‘Read parameter file’. See the AIMMS Help for more information. For this you need AIMMS 4.78.1 or newer.
  • Jun 7, 2021 9:21 AM UTC
