Is it possible to limit the solver session of multi objective optimization for a specific time?
View originalIs it possible to limit the solver session of multi objective optimization for a specific time?
View originalAssume this can help you:
https://how-to.aimms.com/Articles/172/172-use-stop-criteria.html
If you want to limit each of the optimization problems solved during the solving process of a multi-objective optimization problem, you should use parameters files and enable the CPLEX or Gurobi option ‘Read parameter file’. See the AIMMS Help for more information. For this you need AIMMS 4.78.1 or newer.
