Issues importing a parameter from an empty cell
  • August 27, 2024
  • 5 replies
  • 122 views
Hi, everyone!
I’m trying to import a parameter based on a excel sheet. The cell is empty and the parameter is set with a default value of inf, but the parameter keep assuming value of zero. There’s anything that I can do to, if the cell is empty, the value assumed be different than zero?
I don’t know if this should happen or if it’s an issue that has already been fixed. I’m using the verison 4.85, by the way.
Thank you very much!
Hi @beatrizcelante !
I’ve been testing, and I was not able to reproduce it. I am using DEX library (24.0.0.13) to integrate using Excel a parameter that has inf as Default. AIMMS version being 24.5.5.4. Can you share a little bit more on how you are integrating? If you can, can you share a small project as an example of this problem?
Thank you!
  • September 2, 2024
Hi, @gabiservidone !
To integrate, I’m using axll::ReadSingleValue. Doing some tests, I discovered that this issue occurs (sometimes, not always) when I set the value in the excel cell and then return the cell to empty. I don't know if it has anything to do with the format of the cell being in number or not, but sometimes after I turn off the computer and start everything again, the problem is solved.
Thank you!
I’ll try and reproduce that again, but can you create a small example where this problem occurs?
  • September 2, 2024
Sure!
1 -  Excel Sheet.
The value that i’m trying to import are in the cell B blabla. The cell is empty (I already setted a value in this parameter and it works)
2 - Importing at AIMMS - AimmsXLLibrary Version (1.1.0.22)
 Here it is the snippet of code that I’m using
empty P_IMP_LimiteSaqueBB;
empty P_LimiteSaqueBB;
axll::ReadSingleValue(
    ScalarReference :  P_IMP_LimiteDepositoBB,
    Cell            :  FormatString("B%i", P_LinhaAtual));
endblock;
3- Assigning parameters
P_LimiteSaqueBB:= P_IMP_LimiteSaqueBB;
Both P_IMP_LimiteSaqueBB and P_LimiteSaqueBB are with the default set as inf.
Sometimes the P_IMP_LimiteSaqueBB recieves inf and sometimes recieves 0. But P_LimiteSaqueBB  recieves zero for both inf and zero values
Thank you for your help!
Hi @beatrizcelante, I re-tested using multiple AIMMS versions, and was not able to reproduce it… For me, it always return empty cells as zeros. The only difference I see is the AXLL Library version, where I was only able to use 1.1.0.30. Can you update the library and try again?
I’ll contact you directly about this.
