Linearizing step function
  • Aug 5, 2019 1:50 PM UTC
  • 769 views
chrdttchavan
hi all,
need help for linearizing step function.
say "y" is depending on "x" such that,
y= ax if x is between 1 and 2
y= bx if x is between 3 and 4
y= cx if x is between 5 and 6
a, b and c are parameters/constant which will have values 8 or 9.
"y" is not final objective function and a, b and c must choose value either 8 or 9.
solution requested for maximizing/minimizing "y".
thanks.
Hi @chrdttchavan ,
One way of linearizing this is to use binary variables. I would recommend you to create a set Ranges (with index r) - each element in this set corresponds to the different steps/ranges you have for x.
Set
Ranges := data{Range-1, Range-2, Range-3}.
Parameters,
LowerLimit(r) := {1, 3, 5};
UpperLimit(r) := {3, 4, 6};
MultiplicationFactor(r) := {a, b, c};.
BinaryVariable(r).
Now have the following constraints.
Constraint_1
y = sum[r, BinaryVariable(r)*MultiplicationFactor(r)]
Constraint_2
sum[r, BinaryVariable(r)] = 1
Constraint_3(r)
x >= BinaryVariable(r) * LowerLimit(r)
Constraint_4(r)
X <= (1-BinaryVariable(r))*M + UpperLimit(r)
Here, M is a sufficiently large positive number. You can use M = 10 for your case.
You are essentially using BinaryVariable(r) to track in which range does the value of x lie in, and based on the value of BinaryVariable(r), you can calculate the value of y.
  • Aug 6, 2019 9:33 PM UTC
Hi @chrdttchavan ,
Set
Parameters,
BinaryVariable(r).
Constraint_1
Constraint_2
Constraint_3(r)
Constraint_4(r)
Jess Es
  • Grand Master
  • Aug 23, 2019 10:02 PM UTC
Hi @chrdttchavan did this help solve your problem? Or did you find another way? It may help others to know. Thanks 🙂
