model edit create input argument
  • Dec 22, 2022 1:34 PM UTC
  • 132 views
Is there a way to define an input argument via model edting?
I know I can create a procedure and define the body e.g.:
{    _eProc := me::Create(_spProcName, 'procedure', _eSection);
    me::SetAttribute(_eProc, 'body', _spBody);
Best answer by Joost
Hi Marc,
If I remember well, I think you can’t do this directly. I thought you can create a run time parameter and then move that node under the created run time procedure as a ‘trick’ to accomplish this effect. Also thought this was in a how-to somewhere. See me::Move() function.
Joost
  • Ace
  • Dec 22, 2022 7:32 PM UTC
Hi Marc,
Joost
Chris Kuip
  • Dec 24, 2022 10:27 AM UTC
Hi Marc,
Perhaps Joost is referring to this how-to.
With kind regards,
Chris
Thanks Joost, Chris
One note by doing so I found that on https://documentation.aimms.com/language-reference/non-procedural-language-components/set-declaration/set-declaration-and-attributes.html there is a typo.
I wanted to set a subset but the attribute name is ‘subset of’ with a space. (not SubsetOf)
Cheers
