moving elements in a set to the end
  • July 21, 2025
  • 84 views
Forum|alt.badge.img+1
 Let’s say I have a set consisting of 5 elements such that: Set1 = {‘A’,‘B’,‘C’,‘D’,‘E’}.
How can I move some elements to the end of the set. For example:
Set1 = {‘A’, ‘D’,’E’,’B’,’C’}
Best answer by gabiservidone
Below is a step-by-step example with some code to implement!
  1. Define the original set:
    Set Set1 {
    Index : i;
    Members : {'A', 'B', 'C', 'D', 'E'};
  2. Create a parameter to define the sorting order:
    Parameter p_NewOrder {
    IndexDomain : i;
    Definition : Data { 'A': 1, 'D': 2, 'E': 3, 'B': 4, 'C': 5 };
  3. Define a new set with the OrderBy attribute:
    Set OrderedSet1 {
    SubsetOf : Set1;
    OrderBy : p_NewOrder(i);
By executing this code, OrderedSet1 will be automatically sorted based on the values defined in p_NewOrder.
In AIMMS, this transformation can be achieved by creating a new set where the order of elements is specified dynamically. A structured approach is as follows:
  1. Define the Original Set: Create the initial set (e.g., Set1) and populate it with the predefined elements: {'A', 'B', 'C', 'D', 'E'}.
  2. Create a Parameter: Define a parameter to represent the new order. Assign indices to rearrange the elements. For instance, define a parameter p_NewOrder(i) where i represents the elements of Set1. Assign values corresponding to the target order: {'A': 1, 'D': 2, 'E': 3, 'B': 4, 'C': 5}.
  3. Sort Dynamically: Utilize the indexing capabilities to sort the set dynamically based on the parameter values. AIMMS allows reorganization of sets using such logical parameters.
  • July 22, 2025
Thank you so much for your detailed response.
I got a bit lost on the third step. Would you mind sharing the code you would use to do this on your end?
Thanks a lot.
    Set Set1 {
    Index : i;
    IndexDomain : i;
    Set OrderedSet1 {
    SubsetOf : Set1;
