I would like to do a multiple optimization in AIMMS. For example I would concurrently minimize the costs and maximize the amount of captured carbon dioxide.
How can I set this kind of optimization in AIMMS?
Thanks.
Best
You can use the multi-objective optimization functionality in AIMMS for this. It is explained and demonstrated in this article.
Note that you can specify only one optimization direction for the whole set of multi-objectives (minimization or maximization). However, by specifying a negative weight for an objective, you can reverse the optimization direction of any objective.
View originalNote that you can specify only one optimization direction for the whole set of multi-objectives (minimization or maximization). However, by specifying a negative weight for an objective, you can reverse the optimization direction of any objective.
