Multiple Scenario Analysis in AIMMS
  • March 28, 2024
  • 122 views
Forum|alt.badge.img+1
I’m currently doing an optimization model through AIMMS and I want to consider multiple scenarios for my study. Is it possible that I have considered, for example, 100 scenarios and my decision variables will only arrive at one solution that considers all scenarios?
In my case, I only have one varying parameter (waste generation) in each scenario. I just want to clarify if it is possible in AIMMS and I want to know how it happens that it will arrive only at one solution. It would be a great help if you can answer my query. Thank you!
Best answer by Chris Kuip
You may want to use Stochastic Programming (SP) here.
You can find more information about SP in https://documentation.aimms.com/language-reference/optimization-modeling-components/stochastic-programming/index.html
An example using SP is presented at https://how-to.aimms.com/Articles/436/436-stochastic-programming.html
Hope this helps.
Chris Kuip
  • March 28, 2024
Hope this helps.
