Objective function VS CPU time
  • May 16, 2024 5:48 AM UTC
  • 59 views
Hi every one
I would like to implement a cost function VS CPU time curve similarly to the following figure. How we can do it?
thanks for your support
Best answer by gabiservidone
Hi @rabah.ismaen, if you have the data, you can use the Combination Chart Widget to generate a similar graph. See more here: https://documentation.aimms.com/webui/combination-chart-widget.html
And this article may help if you don’t have the data ready: https://how-to.aimms.com/Articles/134/134-Monitoring-Memory-Use.html
