Problemas while converting from AIMMS 3.11 to AIMMS 4+
  • May 21, 2020 12:02 PM UTC
  • 127 views
Good morning,
When trying to convert an old project (AIMMS 3.11) to an AIMMS 4.8 project, new compilation errors appear (attached)
How can I solve it? The old project works properly and the index is really defined.
Thanks in advance!!
Hi @Marcos. You should open the project in AIMMS 3.11 and rename the index cp.
(Since AIMMS 3.13 cp is used as prefix for constraint programming functions and therefore you cannot use it as the name of an index.)
