Profiler Output to a File
  • Jun 5, 2025 3:42 PM UTC
  • 106 views
Can anyone tell me if there is a way to write profiler output to a file?     An external application is invoking AIMMS from the command line multiple times during its run, so it would be useful to generate this file
Best answer by Chris Kuip
hello Tsterle,
You can use the functions ProfilerStart (for instance in MainInitialization) and ProfilerCollectAllData to collect the profiling information, also during a headless run.
Once collected, you can use
write <some identifiers> to file someFile.txt ;
to write the data.
For more information on the profiling functions, see https://documentation.aimms.com/functionreference/development-support/profiler-and-debugger/index.html
Does this answer your question?
With kind regards,
Chris
Chris Kuip
  • Jun 6, 2025 8:54 AM UTC
hello Tsterle,
to write the data.
With kind regards,
Chris
  • Jun 9, 2025 5:22 PM UTC
I believe so, thank you Chris!
