put in loop for writing to text file
  • Jun 3, 2019 9:31 AM UTC
  • 246 views
The CSV Export DLL does seem to export 0-dim identifiers. Therefore I would like to use put.
However I can't figure out how to obtain the value of that 0-dim variable.
I have the next snippet of code, which works fine, but the value of the variable is still missing.
code:
for (IndexVariables) do
if (IdentifierDimension(IndexVariables)) then
!do something else
else
csv_alt_name := FolderName + IndexVariables + ".csv";
put csv_alt;
put IndexVariables + "\n";
put name_of_some_variable;
putclose;
endif;
endfor;
The line "put name_of_some_variable;" prints the value of a variable. But it should of course print the value referred to by IndexVariables. How to do that?
Best answer by Chris Kuip
To obtain the value of the referenced variable, you can use the same technique as used in https://how-to.aimms.com/Articles/146/146-value-dynamic-identifier.html
Hope this helps.
Jess Es
  • Grand Master
  • Jul 11, 2019 9:22 PM UTC
Hi @wiet I'm afraid this question was overlooked for a while - did you find the answer? Or do you still need help?
Chris Kuip
  • Jul 13, 2019 1:33 PM UTC
Hope this helps.
