Question about dex
  • August 22, 2023
  • 66 views
I would like to know if it is possible to start reading files from a certain line when importing an .xlsx file using the dex library. And how could this be done?
I have a file that contains four header lines and I would like to perform the import ignoring those lines.
Thanks
Best answer by MarcelRoelofs
@NataliaAntuness
No, the header should be on the first line, next lines should contain the data. You can specify via the mapping that empty rows should be skipped.
You can add your request to the ideation section, though, and see how others share your wish.
MarcelRoelofs
@NataliaAntuness
