Read data Excel in an order
  • April 17, 2023
  • 131 views
Hi all,
I want to read data from Excel but it should be sorted customly.
In Excel the data is like this:
The result in AIMMS should be this:
I can create this with a text join in Excel and paste the value in the data field in AIMMS but the data changes frequently so I want to automate this with AXLL functions. It is important that the order of a, b and c holds.
Does anyone have an idea to do this?
Best answer by Chris Kuip
After reading in the second column into a string parameter, I'd use the following steps:
  • For each row:
I've enclosed a small working AIMMS 4.94 project.
Let me know if you have questions on the above.
With kind regards,
Chris
Chris Kuip
  • April 18, 2023
  • For each row:
With kind regards,
Chris
  • April 24, 2023
Hi @Chris Kuip ,
It worked! Thank you very much for the example.
