Retrieving solution from asynchronous solving sessions in different GMPs
  • Mar 20, 2020 7:41 PM UTC
  • 132 views
afattahi
I want to solve several GMPs at the same time. I adopted AsynchronousExecute AIMMS example to my code. From the progress window I can see that all GMPs get to an optimal solution. However, I can only retrieve the solution of the last GMP. Here is my code:
I generate 3 GMPs, resolve them, and create one solversession for each of the GMPs:
periods := 3;
for (i in periods) do
myGMP(i) := GMP::Instance::Generate(myMathProgram, "myGMP_" + i);
ProgressWindow := GMP::Instance::CreateProgressCategory(myGMP(i));
presolved_myGMP(i) := GMP::Instance::CreatePresolved(myGMP(ip),"presolved_myGMP_" + ipss);
SolverSession(i) := GMP::Instance::CreateSolverSession(presolved_myGMP(i),"SS_" + i);
GMP::Solution::RetrieveFromModel(presolved_myGMP(i),1);
GMP::Solution::SendToSolverSession(SolverSession(i),1);
GMP::SolverSession::AsynchronousExecute(SolverSession(i));
endfor;
Here I wait until all asynchronous solversessions are solved.
GMP::SolverSession::WaitForCompletion(AllSolverSessions);
Here I want to retrieve the solution (variables, etc.) from solversessions into AIMMS so I can see them and save them.
    GMP::Solution::RetrieveFromSolverSession(SolverSession(i), 1);
    GMP::Solution::SendToModel(presolved_myGMP(i), 1);
    !Write the outcomes of each period solution
    Period_tech_use(t,i):=tech_use(t,i);
    hourly_prices(h,i):=balance_activitiesHourly(h,i).ShadowPrice;
endfor;
unfortunately, I only get the results from the last solved GMP. Do you know how can I retrieve the solution of all solversessions?
@afattahi , in your last piece of code - are you using parameters Period_tech_use(t,i) and hourly_prices(h,i) to store values of the variables tech_use(t,i) and balance_activitiesHourly(h,i)  ?
If yes, then the identifiers on the LHS must have one additional index to those on the RHS and this extra index must be same one that you used to create multiple solver sessions. Something like
for indexSolver do
GMP::Solution::RetrieveFromSolverSession(SolverSession(indexSolver), 1);
GMP::Solution::SendToModel(presolved_myGMP(indexSolver), 1);
Period_tech_use(t,i, indexSolver) := tech_use(t,i);
endfor
What’s happening in your code is that you are overwriting the values in each iteration of the loop. If your RHS was tech_use(t) instead of (t,i), then you would see different values in Period_tech_use(t,i) with your code.
You used the same index i for generating the solver sessions which makes it a bit tricky. I suggest you create a separate set and index like I wrote above.
  • Mar 20, 2020 11:27 PM UTC
for indexSolver do
endfor
afattahi
  • Mar 21, 2020 5:43 AM UTC
You are correct @mohansx, I was mistakenly overwriting the parameters. Thanks!
