Running more than one instances of AIMMS at the same time
  • Mar 9, 2021 4:28 PM UTC
  • 168 views
afattahi
I these days, I realized a new limitation with the new academic license delivery. Before, I was able to run two instances of AIMMS at the same time. However, now I can only run one instance at a time. Here are my two main uses for parallel instances of AIMMS:
  1. I am dealing with a quite heavy energy system model that runs around 2 to 20 hours (depending on the level of details). Sometimes I need to run several scenarios for a specific sensitivity analysis. It would be very useful for me if I can run the model on several computers at the same time.
  2. Sometimes I want to continue coding in AIMMS while it is running a problem.
Would it be possible to run two or more instances of the model at the same time for academia?
Best answer by MarcelRoelofs
Hi @afattahi
Academic licenses do now allow two concurrent sessions.
MarcelRoelofs
Hi @afattahi
  • Mar 9, 2021 9:10 PM UTC
