simple constraint makes model infeasible
  • Jun 25, 2020 10:45 AM UTC
  • 304 views
Hi all,
I am new to AIMMS and I was wondering if someone could help me with my model.
I would like to maximize profit, fulfill as much demand as possible + keeping a safety stock. Besides reorder quantity is restricted by a maximum order quantity (see Sets, Parameters, Variables and Constraints attached).
I linearized min(Demand, E).
E = demand fulfilled
However, when I introduce the maximum order quantity constraints the model becomes infeasible.
Besides, the listing file results in the following messages:
CPLEX 12.10 constructed the following irreducible infeasibility set (IIS).
The IIS consists of 3 constraints and 4 variables.
Stock_definition(B,NL19,p-1) .. [ 9 | 31 | IIS ]
    - 1 * X(B,NL19,p-1) + 1 * Stock(B,NL19,p-1) = -120320 ; (lhs=0) ****
Stock_definition(B,NL33,p-1) .. [ 9 | 43 | IIS ]
    - 1 * X(B,NL33,p-1) + 1 * Stock(B,NL33,p-1) = -428130 ; (lhs=0) ****
OQ_B(p-1) .. [ 9 | 152 | IIS ]
    + 1 * X(B,GB13,p-1) + 1 * X(B,NL19,p-1) + 1 * X(B,NL30,p-1) + 1 * X(B,NL33,p-1) <= 500000 ; (lhs=0)
The variables in the IIS are:
    name               lower level upper
    X(B,GB13,p-1)          0     0   inf
    X(B,NL30,p-1)          0     0   inf
    Stock(B,NL19,p-1)      0     0   inf
    Stock(B,NL33,p-1)      0     0   inf
Can someone explain me what to do?
Many thanks in advance!
Kind regards,
Claire
Hi @ClaireAdrienne. The variable E is not shown in the two Stock_definition constraints which is strange as it is part of the definition of Stock in the model.
It could be that you are loading a case and that the case contains information that freezes the E variable to a certain value (and that would also explain the large negative value in the right-hand-side of Stock_definition). You could try to add the following statement before the solve statement:
empty E;
empty E;
Andrew
  • Aug 25, 2020 6:26 PM UTC
Hi @ClaireAdrienne
Was Marcel’s suggestion able to help you with your model?
