spreadsheet::CreateWorkbook failed: Could not open Excel.
  • Mar 24, 2021 12:28 PM UTC
  • 188 views
spreadsheet::CreateWorkbook(results/Exercise_7/results_demands.xlsx,Energy_demands) failed: Could not open Excel.
:sob: :sob: why
@xyr , that error occurs if you do not have Excel installed on the machine you are using AIMMS. Are you trying to run the model in a VM ?
You have two alternatives
  1. Rewrite your procedure using AXLL functions instead of spreadsheet:: functions. https://how-to.aimms.com/Articles/85/85-using-axll-library.html
  2. Read the Excel file on a machine with Excel installed on it, save a case file, use that case file to load data on the machine without Excel. See the Data menu in AIMMS.
Data → Save case as
  • Mar 24, 2021 6:05 PM UTC
Data → Save case as
  • Ace
  • Sep 30, 2021 3:50 PM UTC
Data → Save case as
Thank you so much.
