Subsets from Excel
  • Apr 27, 2022 5:49 PM UTC
  • 98 views
Hello AIMMS community!
I currently working with aimms on my thesis and for my model i need the MainExecution read a huge amount of sets and parameters. For that I’m using Excel-Sheets. I also going to need subsets and here is my, i think, for you, very simple question:
How can I exclude Excel cells from being readed? For example one of my sets is readed as
Spreadsheet::RetrieveSet ( WorkbookName, facilities, "A4:A75");
If now a subset of facilities is not contigious in this column A4:A75 but instead maybe the cells A10 to A15 and A20 to A30 and A50. How would i retrieve this subset? I tried this (see below) and many other variants and nothing worked. Hope you can help me.
Spreadsheet::RetrieveSet ( WorkbookName, facilities, "A10:A15+A20:A30+A50");
Best answer by deannezhang
Welcome to AIMMS community!
In your case, I suggest
  1. in excel, add a column (for example column B)to your spreadsheet to indicate whether the element in column A belongs to the subset - 1 is yes, 0 or empty is no.
  2. in AIMMS, add a parameter (for example isSubFacility(f) ) to take the value of column B
  3. in AIMMS, add a set (for example subFacility, with index sf), make it a subset of Facility, and add definiton: {f|isSubFacility(f)=1}
  4. then reading in column A to Facility and column B to isSubFacility
and index sf can be used where the subset is needed.
deannezhang
  • Apr 28, 2022 12:45 AM UTC
