Substitute for "sumproduct" Function in Excel
Hey Guys,
I have a small problem by modeling my MILP.
I created a Matrix do define some Binary Variables. Now I want to create a constraint, which contains a multiplication between the Matrix of the Variables an a Matrix with some parameters. The result should be a scalar value comparable to the sumproduct-function in Excel. I want to do a multiplication between the matrices an the result should be a scalar?
Hopefully there is a simple function in Aimms to solve my problem.
I am thankful for every help!
Best regards
Simon
Best answer by gdiepen
If the variables and the parameters share the same indices, this could be done with
sum( (indexOne, indexTwo), yourParameter(indexOne, indexTwo) * BinaryVariable(indexOne, indexTwo))
If this is not what you mean, then please clarify a bit what you want to achieve
  • March 16, 2022
Thank you really much. I had a small mistake in the indices, which caused some problems in my Model.
Thanks a lot!
