Text representation vs. what to put in the AIMMS GUI
  • Apr 26, 2019 2:59 PM UTC
  • 336 views
MathFour
AIMMS Partner
I often have thoughts/suggestions/questions on the documentation that have only to do with the understanding of the language (not AIMMS or anything mathematical). Do we have a sub-forum that users can ask or discuss things about that?
In particular, right now I'm once again running into the situation where the documentation shows the text representation, but yet AIMMS doesn't allow the ability to directly code in text. So I'm wondering if there's a place in the documentation that shows how to convert text representation into what to put in the AIMMS GUI.
~Bon
@MathFour ,
Here is link which describes the file structure of an AIMMS project: https://how-to.aimms.com/Articles/45/45-share-project-files.html
There is a file with extension .ams inside the MainProject folder of every AIMMS project. You can open this file in any text editor and what you'll in this file is the text representation of everything you do in the IDE. This file is tracked by version control systems to keep track of the changes made in the project (identifiers, procedures etc.).
You are correct that AIMMS does not offer the ability to directly code in text, but if you observe the .ams file, you will notice an obvious structure.
code:
Identifier_type Identifier_name {
Attribute_1: Attribute_1_value;
Attribute_2: Attribute_2_value;
Definition: {
some definition
Identifier_type can be a section, a declaration, a set, parameter and so on. Depending on which identifier you select, it will have its own list of attributes. For example, a Procedure has a body and not a definition.
If you are familiar enough with the different AIMMS identifiers, you can write the code directly in this .ams file which will then be loaded into the AIMMS Developer IDE. In the past, some of our users even used a scripting language like R to manipulate this file.
Hope this helps,
Mohan
Jess Es
  • Grand Master
  • Apr 26, 2019 8:44 PM UTC
Hi Bon @MathFour
We certainly welcome feedback on improving the documentation!
Jessica
edit: We've restructured a bit, so Language questions can go to Product Q&A > AIMMS Developer (where I'm moving this topic).
  • Apr 26, 2019 11:00 PM UTC
@MathFour ,
code:
Definition: {
some definition
Hope this helps,
Mohan
