The unit and shadowprice of a constraint
  • May 31, 2024 8:06 AM UTC
  • 52 views
Chris Kuip
Today I got a question on support whether the unit of a constraint influences the shadowprice; for instance, what is the consequence of using [ton] instead of [kg] on the unit of constraint for the shadowprice.
A small example illustrates the effects:
Variable x {
    Range: free;
    Unit: kg;
Constraint limX {
    Unit: ton;
    Property: ShadowPrice;
    Definition: x <= 5[kg];
Variable o {
    Range: free;
    Unit: kg;
    Definition: x;
The base unit of Mass is kg.
Running the model, the shadowprice returned for limX was 1; indicating that increasing the rhs by 1 unit (kg), will increase the objective by 1.
Then I changed the unit of limX to ton, and solved the model again.
The shadowprice returned was 1000; indicating that increasing the rhs by1 unit (ton), increased the objective by 1000.
See also: https://documentation.aimms.com/language-reference/optimization-modeling-components/variable-and-constraint-declaration/constraint-declaration-and-attributes.html#constraint-levels-bounds-and-marginals
