Time Restriction
  • 28 December 2019
  • 70 views
Hello Members,
i want to add a time restriction constraint in my model in which i have variable s(i,j,k) for time where i and j belongs to node and k belongs to vehicle.
i want to add a constraint which will ensure that each vehicle will not work more than 8 hours.
Provide the possible formulation against this constraint.
Looking forward for response.
Best answer by Mischa 31 December 2019, 12:18
Userlevel 3
Badge +6
Hi Muhammad,
If I understand your question correctly, I think you should add a constraint called something like
LimitTime(k)
with definition
sum((i, j), s(i, j, k)) <= 8;
In English, this states that for every vehicle k, the total sum of its time s, as distributed over the (i, j) pairs, should be 8 or less.
I hope this helps!
Regards,
Mischa
Thank you for your response.
I added this already and it works.
Regards
Muhammad Furqan
