Are you developing applications in AIMMS? Then security is probably something you have to comply with, but you don’t want your security considerations to get in the way of the user experience. If that’s the case, this article is important for you.
In most cases, your IT team will require that you use tools and software that are up-to-date when it comes to security standards. AIMMS is evolving to incorporate the latest security components as well. If your IT department requires you to use the latest security updates, and you are using an AIMMS version that doesn’t have the latest updates incorporated, your applications will fail.
This is why we advise you to keep your AIMMS and AIMMS PRO software up-to-date. This helps you stay compliant with your IT department’s requirements, and allows your end-users to continue using your application without interruptions.
For more on this topic, check out @Chris Kuip’s new How-to on the use of the Transport Layer Security in AIMMS and in AIMMS PRO.
Be the first to reply!
