Unable to access repository
  • 23 April 2023
  • 8 replies
  • 48 views
Badge +4
When I tried to add library from repository, I got the error:
Unable to get the list of available libraries from repository.
Can you tell me how to deal with it?
Best answer by luis 7 July 2023, 10:56
Badge +6
Hi @Chunyang which AIMMS version you are using and which library you wanted to add?
Badge +4
Hi, I am using the AIMMS 4.91.1.1, I hope to add the XLLibrary from Repository Library. However, when I click the Add Library from Repository, I get the error: Unable to get the list of available libraries from repository.
Userlevel 4
Badge +6
Hello Chunyang,
This could be a networking/security limitation that doesn't allow you to download our library information.
Can you please try to access https://library-repository.aimms.com:443/libs/7D23E0F3-1030-49F7-9E07-3482C63D8997/1.1.0.7/vc141_x64_Release.alib ? This is an example of a library file that is download via the library repository. If you get blocked, I would suggest talking with your IT to whitelist our library-repository.aimms.com url.
Thanks
Badge +4
Hello Chunyang,
Thanks
Hi thanks for the reply, I have tried to click the link directly and had the document downloaded. Does it mean I don’t get blocked?
Userlevel 4
Badge +6
You shouldn't be blocked in this case.
Have you tried on a separate network or on a different computer?
It is good so we can check if it is a specific error or more general
Badge +4
Hi I can do this on my laptop, and now I have just copied the the software file on my laptop to my PC and the PC can do it too.
I am glad to hear that it resolved your issue.
Since it does work on a different computer on the same network, I suspect something is interfering with some communication aspect between AIMMS and the library repository. Maybe security/antivirus/firewall?
Badge +4
Yes, I agree with that, because I am using the university managed computer. Thanks for the reply.
