What type of variables are x and y? Binary, integer, or continuous?
both are integer variables.
But kan x also be greater than y? That is not completely clear to me from what you write.
yes, that’s right. x can also be greater than y.
so in short i compare two variables and want both to adopt the lower value.
One way to approach this is to introduce an auxillary variable z(t,k) and solve for following
Max z(t,k)
s.t
z(t,k) <= x(t,k)
z(t,k) <= y(t,k)
Other way, you can try out is:
Write following constraints (introduce dummy binary variable delta(t,k) and build following relations)
x(t,k) <= y(t,k) + (big-M)*delta(t,k)
x(t,k) >= y(t,k) -(big-M) *(1-delta(t,k))
Write Indicator constraints in AIMMS as
if delta(t,k)=0 then z(t,k) = x(t,k)
if delta(t,k)=1 then z(t,k) = y(t,k)
Best Wishes,
Kumar.
Hi @Sebastian Schäfer
Did @akumar ‘s answer help you with your solution?
