Use initial MIP start for Gurobi
  • Jan 26, 2023 6:06 PM UTC
  • 138 views
Hi all,
I found the setting to use an intial solution in AIMMS for Gurobi, however, how and where do you efficiently add this initial solution in AIMMS?
Can I export an AIMMS output and read it again to use as the intial value? If so, how?
I found this topic, but the link does not work: How to start solving with an initial solution | AIMMS Community
You have to assign level values to the variables before you call the solve statement. You can do that using an assignment statement like
x(i,j) := p(i,j);
or read the variable values from a case file (if you have stored them in the case file), or from some other data source.
Hi @GaboriauArthur ,
I already saw that article and also set the settings according to it.
But how do I set the intitial values and where do I set them (e.g. in the MainExecution or somewhere else) because I have a model with a lot of variables and entering them manually is not efficient.
x(i,j) := p(i,j);
