Good morning all,
Please, can someone tell me why I keep getting this error ? Both SOC(agg,t) and P_Charging(agg,t) are variables.
Thanks so much.
![](https://uploads-eu-west-1.insided.com/aimms-en/attachment/ab83dc45-c10b-461a-b678-404765da6706.png)
View originalGood morning all,
Thanks so much.
The problem is with your “else” block. This is a constraint and not a variable definition, so
else
P_Charging(agg, t)
endif
does not make any sense. You can simply have
IF SOC(agg, t-1) > 0.949 THEN
P_Charging(agg, t) = 0
ENDIF
Thanks
Thanks
I tried that suggestion and it still gives error of missing “ELSE” part. Sincerely this looks so simple to tackle personally considering what I have done in AIMMS but I really dont know why I cant resolve it. Any further help would be greatly appreciated.
Thanks
Hello
Apologies, I missed that AIMMS requires IF blocks in constraints to have ELSE conditions too.
You have two options -
0
ELSE
P_Charging(agg, t)
ENDIF
constraint1
SOC(agg, t-1) <= 0.949 + U1 * Y(agg, t)
constraint2
P_Charging(agg, t) <= 0 + U2 * (1 - Y(agg, t))
If SOC(agg, t-1) needs to be greater than 0.949, Y(agg, t) must be 1 which will force the second constraint to become P_Charging(agg, t) <= 0 + 0 = 0 (assuming the range of P_Charging is nonnegative).
I hope this helps.
Hello
Thanks for your response. My system went for some maintenance and just returned with it. I will let you know if your suggestion solves my problem.
Thanks again
Olusegun
Hi
Sorry to bother you again on the above subject.
Please I want to ask what happens if range of P_Charging is nonpositive, that is it must be negative or zero?
Please, what will now be U2?
Thanks in advance for your prompt response.
Olusegun
will become something like
P_Charging(agg, t) >= L2 * (1 - Y(agg, t))
When Y is 0, this will be P_Charging >= L2 and when Y = 1 - P_Charging >= 0 which will force it to be P_charging = 0 because of the range L2 <= P_Charging <= 0
