Using the Logical iterative operator Exists to verify a SET in the domain
  • December 3, 2023
  • 157 views
Forum|alt.badge.img+1
Is it possible to use an indexed set inside the domain of Exists?
For instance:
  1. I have an indexed set IS with index domain (a,b) and subset of c
  2. I want to define a new set NS which is a subset of b and c
  3. Is it possible to use in the definition of this new set NS the following expression:
    { (b,c) | Exists[ a | c in IS(a,b) ] }
Thank you
Best answer by gdiepen
Instead of seeing the items as set elements, you can just define them as a relation using a binary parameter.
In your case you could create a binary parameter pIsPartOfIS(a,b,c) which gets a value 1 if c ‘is an element of the indexed set IS(a,b)’ and 0 otherwise.
Then your pIsPartOfNS(b,c) is just a new binary parameter with the definition exists(a | pIsPartOfIS(a,b,c)
Hope this is clear enough
  • December 4, 2023
Instead of index sets, I typically try to use just binary parameters that indicate the relations instead.
  • December 4, 2023
Thank you @gdiepen
Could you provide me an example or reference to understand what you are suggesting?
RM
  • December 4, 2023
