Variable with Initial Value
  • Jul 28, 2022 8:47 AM UTC
  • 186 views
Hi everybod,
I have a quick question and hope you can help me.
I calculate in my model the optimal stock level depending on the period and szenario specific demand.
The inventory level is defined as follows: Inventory_PreviousPeriod + ProductionQuantity_CurrentPeriod (also a variable) - DeliveryQuantity_CurrentPeriod.
How is it possible to preset the variable stock for the first period to a fixed inital value (in this case the opening inventory)?
I would be very grateful for your answer!
Best ragards, Hans
Best answer by luispinto
Hello Hans,
I typically do this by including the initial stock from a parameter and conditioning that this will only be added if the constraint is being applied for the first period.
Something like this:
Constraint c_balance {
    IndexDomain: (i_period);
    Definition:
        (p_initialInventory | (i_period = 'period_1’)) + v_inventory(i_period - 1) + v_production(i_period) = v_delivery(i_period) + v_inventory(i_period)
Hence the “| (i_period = 'period_1’)" will only add the p_initialInventory parameter when i_periodo is ‘period_1’.
Best regards,
luispinto
  • Customer Success Manager
  • Jul 28, 2022 9:22 PM UTC
Hello Hans,
    Definition:
Best regards,
  • Aug 1, 2022 3:55 PM UTC
Hu Luispinto,
thank you for your helpful reply!
This is exactly the kind of advice I was hoping for, you really helped me a lot.
Thanks again and best regards,
Hans
