Variable with limited set index
  • December 26, 2019
  • 5 replies
  • 195 views
rahmat
Dear All,
I want to model a variable that only can be applied for certaint set index. For example:
Variable NPGMax {
    IndexDomain: (i,g,ng)|ord(i) = 1 or ord(i) = 3 or ord(i) = 6;
where the variable NPGMax is only applied for index 1, 3, or 6 of set bus with index i.
Is it possibel to do it dynamiclly where the value 1,3, or 6 can be assigned as an input parameter?
Thank you very much.
Best answer by Arthur
Hi @rahmat ,
I recommend you to declare a binary parameter indexed over your set, say BP_SelectedVariables(i), and apply this parameter in the domain condition of your variable:
Parameter BP_SelectedVariables {
    IndexDomain: (i);
    Range: binary;
Variable NPGMax {
    IndexDomain: (i,g,ng)| BP_SelectedVariables(i)
This BP_SelectedVariables can then be updated through an assignment in a procedure, or directly in your user interface (it will show some checkboxes)
As soon as BP_SelectedVarialbles is updated, the variable is updated too.
Arthur
Forum|alt.badge.img+1
  • December 27, 2019
Hi @rahmat ,
    IndexDomain: (i);
    Range: binary;
Variable NPGMax {
rahmat
  • Ace
  • December 30, 2019
Hi @Arthur,
Many thanks for your suggestion. It works well…
Thank you.
rahmat
  • Ace
  • January 7, 2020
Hello @Arthur,
Based on your reply, the approach can be used to substitute the compound set (that no longer supported by AIMMS). For example:
Set Bus {
    Index: i
Set GenTech {
    Index: g;
Set GenNum {
    Index: ng;
Set NewGen {
    SubsetOf: (Bus, GenTech);
    Index: cg;
Variable NPGMax {
    IndexDomain: (cg,ng);
    Range: integer;
can be replaced by:
Parameter NewGenBus {
   IndexDomain: (i,g);
   Range: binary;
Variable NPGMax {
    IndexDomain: (i,g,ng) | NewGenBus(i,g)
    Range: integer;
Is this correct?
  • January 7, 2020
@rahmat , yes. The binary parameter acts as a condition to generate the valid tuples. NewGenBus(Bus1, GenTech1) = 1 indicates that NewGen is possible with i = Bus1 and g = GenTech1
rahmat
  • Ace
  • January 8, 2020
@mohansx, thanks a lot...
