visualization of data frequency
i want to visualize the frequency of postcodes from a table with a barchart,
 but I didnt have any ideas how to do this. Can somebody help?
Thanks
Best answer by mateusarakawa
Hi, @Gergely.
I would create a set called S_AllePostleitzahlen with attributes ‘Index’ set to “PLZ” and ‘Parameter’ set to “Pe_PLZ”:
Then I would populate this set with all possible PLZ:
Remark: you can also populate it easily with every PLZ that has frequency >= 1 using your original table Hilfsbeduerftige(i), that I named P_YourOriginalTable(i,) using a procedure:
After that, I would create a parameter P_PostleitzahlHaufigkeit(PLZ) that counts the PLZ frequency:
and then you can use this parameter (P_PostleitzahlHaufigkeit(PLZ)) directly on the barchart object.
Idk if it’s the best approach but it works. Hope it helps!
mateusarakawa
Hi, @Gergely.
  • July 11, 2020
Thank you for your fast response, you helped me a lot.
  • July 12, 2020
Hi @Gergely , would be great if you share how you solved it and show a screendump of the end result. Would be a nice share as I am sure  there are more people interested.
