Warning: The local index is modified inside the for loop
  • Mar 2, 2020 10:39 AM UTC
  • 233 views
In my application, I need to do some stuff with subsets of different sizes of some superset. So I created a set containing the sizes of the subsets and loop over this set of sizes. In each iteration, I extract the subset from the big set using NBest procedure.
The sizes of the subsets are ordered in descending order. The use of NBest raises the warning “The local index "_i_SizeOfSubset" is modified inside the for loop.  The condition of the for loop will be re-evaluated, which can be time consuming.  For details on this warning message see the help of the option warning_time_consuming_for_threshold.”.
I don’t understand why _i_SizeOfSubset needs to be modified if I pass it to NBest. Using val(_i_SizeOfSubset) does not help either.
Could somebody explain to me please, why the warning is issued, and how this could be formulated without modification of _i_SizeOfSubset inside the loop?
Procedure PR_SampleLoop {
Body: {
_S_SizeOfSubset := {1 .. card(S_BigSet)};
for (_i_SizeOfSubset) do
!Raises "Warning: The local index "_i_SizeOfSubset" is modified inside the for loop.
! The condition of the for loop will be re-evaluated, which can be time consuming.
! For details on this warning message see the help of the option warning_time_consuming_for_threshold."
_S_SmallSubset := NBest(i_ElementOfBigSet,
ord(i_ElementOfBigSet),
_i_SizeOfSubset);
!Do some stuff with _S_SmallSubset
endfor;
Set _S_SmallSubset {
SubsetOf: S_BigSet;
Index: _i_SmallElement;
OrderBy: User;
Set _S_SizeOfSubset {
SubsetOf: Integers;
Index: _i_SizeOfSubset;
Property: ElementsAreNumerical;
OrderBy: -_i_SizeOfSubset;
DeclarationSection __unnamed {
Set S_BigSet {
Index: i_ElementOfBigSet;
Definition: {
ElementRange(From : 1,
To : 1000,
Prefix : "Element_");
@Benedikt , this warning seems to be popping up only when these sets are locally declared. If you declare s_SizeOfSubset globally, there’s no warning. We will investigate this further.
Modifying the for loop with a keyword as suggested in the description of the warning also returns same results.
ordered for _i_SizeOfSubset do
endfor
If you are using ord(_i_SizeOfSubset), I wonder what is the need to order this set in a decreasing manner ?
mateusarakawa
Hi, @Benedikt.
I think, it doesn’t matter to AIMMS if you call other procedure/function (NBest) to change _S_SizeOfSubset (_i_SizeOfSubset), you are still doing it inside its own “for” loop, hence it can lead to strange behaviors. That’s why AIMMS is reevaluating the elements that it can go through.
I needed to understand better you code, but when you face problems like this (recursive-style), you can create an auxiliary local set to map the elements that you already considered.
Other idea is to use while (condition) instead of for…
  • Mar 3, 2020 12:25 AM UTC
endfor
  • Mar 3, 2020 6:53 AM UTC
@mateusarakawa :
From my point of view, passing _i_SizeOfSubset as the third(!) argument to NBest, does not modify the contents of _S_SizeOfSubset. Please note that I’m getting the n best elements of S_BigSet and store them in _S_SmallSet, which are both unrelated to _S_SizeOfSubset.
@mohansx : In NBest, I used ord(i_ElementOfBigSet) as the expression to order S_BigSet, not ord(_i_SizeOfSubset). In my real application, I order S_BigSet based on a more complicated criteria, which I left out for the simplicity of the example.
I would like to order _S_SizeOfSubset in decreasing order, because the “do some stuff with _S_SmallSubset” depends on that we start with the subset of highest cardinality and continue with smaller and smaller subsets of S_BigSet.
Thank you both for your help. I’ll probably follow your suggestion, @mohansx , and declare S_SizeOfSubset globally, until this get’s fixed.
  • Apr 29, 2020 6:03 PM UTC
@Benedikt , a fix for this has been released in version 4.73 earlier today !
