Dear all,
I want to write a code in the MainExecution section.
I want to consider in the first cycle a constraint, but I wan't to consider this constraint in the second cycle.
How can I write this?
Thanks
Best
GL
Dear all,
I have this error in my code:
The set "Integers" does not denote a subset of the set "e_set".
How can I solve it?
Thanks.
Best
GL
How can I solve it?
Thanks.
Best
GL
Please review below article, it shows you how to select/deselect multiple variables and constraints from a math program.
https://how-to.aimms.com/Articles/175/175-select-variables-and-constraints-for-math-program.html
For your case, it might be easiest to declare a parameter with Initial data as 1. Say, pConstraintActive.
In the Index domain of the constraint you want to use in cycle 1 and not use in Cycle 2, include this parameter.
code:
(i, j) | pConstraintActive
This will make the constraint active only if pConstraintActive has a nonzero value.
Now, your procedure will be.
code:
!solve with constraint
pConstraintActive := 1;
solve MathModel;
!solve without constraint
pConstraintActive := 0;
solve MathModel;
Note that you will need to store the results between two subsequent runs so that you don't lose the results from the first solve run when you run the solve statement the second time.
dear @mohansx ,
thanks for your replay. However, how can I relate this parameter to the constraint?
Best
GL
Best
GL
The parameter must go in the index domain condition of the constraint.
code:
Constraint your_constraint {
IndexDomain: (i,j)
Definition: constraint definition;
must become
code:
IndexDomain: (i,j)|pConstraintActive
dear @mohansx
how should be the pareto curve if one function is minimized and another function is maximized?
Thanks
GL
Thanks
GL
