Writing a constraint
  • 27 December 2020
  • 5 replies
  • 192 views
Userlevel 1
Badge +3
Dear staff,
I would like to receive some help writing the following constraint for a mathematical model.
Within a graph, I define arcs (i-j) where “i” and “j” are nodes. For each arc and node, I also have the following variables and parameters:
p(i) binary variable
p(j) binary variable
a(i,j) continuous variable
C(i,j) parameter
H(i) parameter
H(j) parameter
I would like to write a constraint expressing the following conditions:
if p(i) = 1 and p(j) = 0, then a(i,j) <= C(i,j)*H(j)
if p(i) = 0 and p(j) = 1, then a(i,j) <= C(i,j)*H(i)
if p(i) = 0 and p(j) = 0, then  a(i,j) <= C(i,j) * (H(i) + H(j))/2
if p(i) = 1 and p(j) = 1, then a(i,j) <= C(i,j)
If you have any suggestions on how to write the above conditions within a constraint, I will be glad.
Thank you,
Best answer by Marcel Hunting 28 December 2020, 17:59
Badge +4
This is getting somewhat ugly. I would use indicator constraints; see section 14.2.4 in the Language Reference for more information.
p(i) = 1  →  a(i,j) <= C(i,j)*H(j)*(1-p(j)) + C(i,j)*p(j)
p(j) = 1  →  a(i,j) <= C(i,j)*H(i)*(1-p(i)) + C(i,j)*p(i)
p(i) = 0  →  a(i,j) <= C(i,j) * (H(i) + H(j))/2 * (1-p(j)) + M*p(j)
Here M is a big number (“big M”). The left part of each of these three constraints represents the activating condition.
Please note that indicator constraints are only supported by CPLEX and Gurobi.
Userlevel 1
Badge +3
Thanks very much!
That’s indeed a good idea to try with indicator constraints. I haven’t thought about it. I will give it a try!
Userlevel 1
Badge +3
Dear staff,
I would like to ask you further help for a potential extension of the constraint mentioned in the previous messages. (I don’t know if I should open a separate discussion for this, but I try to continue here for now).
Within a graph, I define arcs (i-j) where “i” and “j” are nodes. For each arc and node, I also have the following variables and parameters (basically, there is a new index “y” compared to the previous case):
p(i,y) binary variable
p(j,y) binary variable
a(i,j,y) continuous variable
C(i,j) parameter
H(i,y) parameter
H(j,y) parameter
For all y,
if sum(y1|((ord(y1)<=ord(y)), p(i,y1)) = 1 and sum(y1|((ord(y1)<=ord(y)), p(j,y1)) = 0, then a(i,j,y) <= C(i,j)*H(j,y)
if sum(y1|((ord(y1)<=ord(y)), p(i,y1)) = 0 and sum(y1|((ord(y1)<=ord(y)), p(j,y1)) = 1, then a(i,j,y) <= C(i,j)*H(i,y)
if sum(y1|((ord(y1)<=ord(y)), p(i,y1)) = 0 and sum(y1|((ord(y1)<=ord(y)), p(j,y1)) = 0, then  a(i,j,y) <= C(i,j) * (H(i,y) + H(j,y))/2
if sum(y1|((ord(y1)<=ord(y)), p(i,y1)) = 1 and sum(y1|((ord(y1)<=ord(y)), p(j,y1)) = 1, then a(i,j,y) <= C(i,j)
If you have any suggestions on how to write the above extended conditions within a set of constraint, I will be glad. I am not sure about the possibility of including the summation together with the indicator constraints.
Thank you,
Badge +5
Hi @Chibo, i and j are indices of same set. So, create a new variable varSum(i, y) like below
sum[y1|(ord(y1)<= ord(y)), p(i, y1)] = varSum(i, y)
sum[y1|(ord(y1)<= ord(y)), p(j, y1)] = varSum(j, y)
varSum can be binary as your post suggests that the above sums are either 0 or 1.
Create another auxillary binary variable auxVar(y) with below constraints. forall (i, y)
auxVar(y) >= varSum(i, y)
auxVar(y) >= varSum(j, y)
auxVar(y) <= varSum(i, y) + varSum(j, y)
Now, for the constraint you would like to write - forall (i, j, y)
a(i, j, y) <= C(i, j) * [H(i, y)/2 + H(j, y)/2
- varSum(i)*H(i, y)/2 - varSum(j)*H(j, y)/2
+ varSum(i, y) + varSum(j, y) - auxVar(y)]
As H and C are parameters, there is no multiplication of variables here. the 4 cases in your constraint will evaluate as
1. varSum(i, y) = 1, varSum(j, y) = 0 -> auxVar(y) = 1 & a(i, j, y) <= C(i, j) * H(j,y)/2
2. varSum(i, y) = 0, varSum(j, y) = 1 -> auxVar(y) = 1 & a(i, j, y) <= C(i, j) * H(i,y)/2
3. varSum(i, y) = 0, varSum(j, y) = 0 -> auxVar(y) = 0 & a(i, j, y) <= C(i, j) * (H(i,y)/2 + H(j, y)/2)
4. varSum(i, y) = 1, varSum(j, y) = 1 -> auxVar(y) = 1 & a(i, j, y) <= C(i, j) * 1
It might have gotten some of the indices wrong but this should work for your case. Using varSum is not necessary, you can directly type in the sum[..] expression but you will need the additional auxVar constraint.
Userlevel 1
Badge +3
Thank you very much for your precious inputs.
I will try to implement them
