Writing Program and Solver Status using Dex: values rather than labels
  • 29 August 2023
  • 21 views
Badge +1
While writing the suffices ProgramStatus and SolverStatus from a MathematicalProgram identifier to an Excel file using DEX I get numeric values rather than the lables indicated in this table:
https://documentation.aimms.com/language-reference/optimization-modeling-components/solving-mathematical-programs/suffices-and-callbacks.html#table-mp-status
Is there any way to write these labels rather than the corresponding numeric values?
Otherwise, where could I find the corresponding mapping between the numeric values and the labels (status) referred in the previous table?
Best answer by gdiepen 30 August 2023, 20:45
Badge +7
Not sure what code you are using to write the values, but one way you could force it to be a string is to use something like:
formatstring(“%e”, mpProblem.ProgramStatus)
Badge +1
 Thank you @gdiepen for your inputs.
I am using DEX to write the values into an Excel file. The code is the following:
<AimmsExcelMapping>
<ExcelSheetMapping name="Summary">
<RowMapping>
<ColumnMapping name="Program Status" maps-to="MathematicalProgram.ProgramStatus" />
<ColumnMapping name="Solver Status" maps-to="MathematicalProgram.SolverStatus" />
</ExcelSheetMapping>
</AimmsExcelMapping>
Note that I believe I cannot use formatstring(“%e”, MathematicalProgram.ProgramStatus) in DEX
Badge +7
What are the numbers that you see being written to Excel? Are those the ordinal values of these elements by any chance?
I think you might need somebody from AIMMS help out to really fix it (or provide the way it should work).
As a work-around, you could create two parameters:
spMathematicalProgramProgramStatus with definition formatstring(“%e”, MathematicalProgram.ProgramStatus)
spMathematicalProgramSolverStatus with definition formatstring(“%e”, MathematicalProgram.SolverStatus)
and write those two items to the excel file?
