aimms.py Error
  • Jul 29, 2025 8:32 AM UTC
  • 57 views
Dear,
I am trying to use aimms.py in order to run a AIMMS model from python and parse and receive output.
I created the following python script based on the package: aimmspy · PyPI.
import os
from aimmspy.project.project import Project, Model
from aimmspy.utils import find_aimms_path
aimms_bin_path = r"C:\Users…..."
project_file = r"C:\Users…..aimms"
# input_file = r"C:\Users....txt"
results_file = r"C:\Users....csv"
project = Project(
    # path to the AIMMS Bin folder (on linux the Lib folder)
    aimms_path=aimms_bin_path,
    aimms_project_file=project_file,
    license_url=R"wss://licensing…….."
my_aimms : Model = project.get_model(__file__)
my_aimms.GuiReadData()
After running the script (with proper paths and license), I get Unable to load IBM CPLEX library. Exiting.
I tried to change the solver within AIMMS but still the same error occurs.
Is there anyone that encountered the same issue?
I look forward to a reply.
Kind regards,
Jesper
Hi ​@Jesper. The error is harmless but to get rid of it you should remove the solver ODH-CPLEX from the solver configuration.
