Create library for combining multiple math programs?
  • March 6, 2025
  • 53 views
I have multiple math programs, each related to a different energy supply sector.. I want to keep their development and version control independent. Is making them into libraries a reasonable way to combine these otherwise independent math programs?
Best answer by Chris Kuip
Hi Michael,
Yes that is a good way to combine multiple modeling applications.
Besides taking care of version control per library,
you need to make a choice for your mathematical program(s):
* Do you want to combine all your variables and constraints into one mathematical program, or
* do you want to keep a separate mathematical program per library?
When you want to combine them to one large mathematical program, you can declare a mathematical program in you main model,and
then use AllConstraints and AllVariables which include also the variables and constraints in your libraries.
When you want to keep a mathematical program per library, you can select the variables and constraints in that lbrary easily.
Say you have a library myLib, then you can declare a
set myLibVariables,
as a subset of AllVariables, and
having definition AllVariables * myLib.
Another example of this mechanism is presented at https://how-to.aimms.com/Articles/175/175-select-variables-and-constraints-for-math-program.html#selecting-constraints-or-variables
Going one step further, by using these subsets of AllVariables and AllConstraints, you can freely combine portions of your libraries.
Hope this helps,
Chris.
Chris Kuip
  • March 7, 2025
Hi Michael,
set myLibVariables,
Hope this helps,
Chris.
