Need help with missing element error when loading AIMMS File
  • Sep 18, 2024 12:14 PM UTC
  • 58 views
Hello!
I was writting to see if anyone would be able to help me; you see, when I start up my AIMMS project file I get an error (which can be seen on the shared screenshot) about missing some kind of element in my project library.
This started happening after moving my AIMMS project files from one computer to another, so I suspect that some data might not have transfered properly. In any case, I was hoping someone would be able to help me, as this is kind of urgent to be honest.
Thank you very much in advance!
Pablo
Best answer by gabiservidone
Hi @Baste, which version you used to use in your other computer? And which AIMMS version are you using now?
It seems to be an error related to opening new AIMMS versions projects (with the updated libraries) in older AIMMS versions.
