Debugging PRO-enabled Project
  • May 13, 2020
  • 210 views
this article describes how we can debug on the pro platform: https://documentation.aimms.com/pro/debugging-pro.html .
However, this is not supported for WebUI projects. Is is possible to do this in another way?
Best answer by mateusarakawa
Hi, @OlmoVerhagen .
We do use this feature for debugging general procedures in WebUI projects as a PRO User, but we never used for webUI optimization models (actually I got an update from @splugues that they we are using it to debug webUI optimization models).
Basically, we publish the webUI app on our on-premise/AimmsCloud server and we generate the pro_arguments.txt file. Then, we open our aimms developer project. Aimms asks us to login and we access the webUI as a PRO user through the same button:
I know that some behaviors are slightly different, because you’re local, e.g. download/upload excel, but it helps us a lot to debug some procedures as a PRO user and allows us to have access to PROCentralStorage.
mateusarakawa
  • May 13, 2020
Hi, @OlmoVerhagen .
MarcelRoelofs
Actually,  https://documentation.aimms.com/pro/debugging-pro.html  has never been about debugging your model on the PRO platform, but it is about debugging the way optimization models are executed in the PRO/Cloud environment, on your developer machine. After the optimization request is created (but not executed) on the PRO/Cloud platform in the ‘client’ session, you can emulate the server-side session by re-running the AIMMS model, with the pro_arguments.txt and debug_arguments.txt files present, allowing you to debug the server-side flow of execution as it would have taken place in an actual server-side session (which you will never have direct access to).
Whether the ‘client’ session you run on your desktop is actually just running procedures in the model from within the IDE, or executed by pressing buttons from within a Windows UI or a WebUI session started from within the IDE, doesn’t have any influence on that capability.
