Can we combine the legend and multiselect widgets?
  • 20 November 2019
  • 154 views
Userlevel 3
  • 22 replies
I have proposed the same feature as product idea, as I think it would be very valuable. Since it might take a while to release, in the meantime, is there any way to style the mutliselect through css to mimic the same behavior?
Best answer by Pratap Kumble 6 December 2019, 12:51
Userlevel 4
Badge +2
Hi @Richard,
We could manage to change the way the checkboxes look in the Multiselect widget to micic that of the Legend. So you get both functionality with this change.
Formally not supported, but easily achievable.
We used annotations to make this change. Basically used the annotation that is common for the widgets. Details https://community.aimms.com/aimms-webui-44/colors-in-legend-widget-468
I added the style by targeting the data-annotations attribute in the multiselect.
Attached is the example model with the CSS as well.
Hope this works for you.
Please let me know if you have any questions.
Thanks.
Hi @Richard
Was Pratap’s solution able to help you with your request?
Best Regards
Userlevel 3
Hi @Andrew and @Pratap Kumble, sorry for not replying earlier. The proposed solution is great! Relatively easy to implement, and achieves the goal I needed. Thanks :grinning:
