I am unable to create a simple custom widget using the AIMMS widget framework documentation from https://documentation.aimms.com/webui/dev-tut-1.html#your-first-custom-widget.
I have reproduced all the steps as listed in the above webpage including
- Using NetworkData folder
- Creating subfolders in MainProject/WebUI/resources
- Creating the js files
- Trying to add the the widget (after refreshing page)
I want to use the custom widget for two functions
- Visualization for javascript d3 library
- Embedding an html file in the widget
Is anyone facing a similar problem/ or is aware of a solution (or an easier alternative)?
