Empty space workflow
  • October 7, 2019
  • 5 replies
  • 167 views
Is it possible to create some empty space in the workflow panel?
I want to put the "result" page at the bottom of the workflow.
Best answer by Pratap Kumble
Hi @OlmoVerhagen,
You can achieve this with Custom CSS.
  1. Create a page, lets say Workflow Step Hidden, in the page manager.
  2. Hide the page from the navigation via the Visibility option.
  3. In the string parameter you use to define the steps, create some steps with only data filled for the pageId = workflow_step_hidden and workflowPageState = Inactive
  4. Create a Custom CSS file and add the below code to the file:
code:
.workflow-panel .step-item[data-page-id="workflow_step_hidden"] {
visibility: hidden;
Data would look like:
You should see the following result:
Please let me know if this worked.
Pratap
Patrick
  • Administrator
  • October 7, 2019
We are having a look @OlmoVerhagen, expect an answer the coming days.
  • October 11, 2019
Hi @OlmoVerhagen,
code:
visibility: hidden;
Pratap
  • October 16, 2019
Thanks for your answer! WIll test in next week :)
  • October 17, 2019
It’s working!
Patrick
  • Administrator
  • October 17, 2019
Would love to see the result one day @OlmoVerhagen!
