How to adjust selectionbox dropdown styles for just one widget?
  • February 14, 2020
  • 212 views
MathFour
AIMMS Partner
It seems the data-widget.uri selector for the selectionbox widget can only be accessed in the div of the code that manages the non-dropdown options.
The div that controls the dropdown options is farther down and does not have the data-widget.uri selector available.
How can I change the styling of the fonts in the dropdown box if I want to change them for exactly ONE selectionbox widget only?
Best answer by Edo Nijmeijer
Hi Bon,
Good oberservation, which, unfortunately for you, is correct: the items in the dropdown are kept apart in different parts of the document tree. It makes it easier for them to be hovering over other items.
But it also means there’s no css-setup that can bring them together.
Some background: for the component itself they are technically tied by the id, but since that is automatically generated, based on the presence of other dropdowns too, there still is no stable id to use in your css, nor would you be able to use it ‘dynamically’ in css. And the order of opening your dropdowns also plays a role. Just look at the id on the <ul> within the select2-drop element you showed above: it varies. We really are out of luck.
Time to think about alternatives. Perhaps it is manageable to work with multiselect lists that are shown and hidden based on other ‘circumstances’? You could style all of those individually. Otherwise I’m not too sure right now.
How can the ‘function’ of these dropdowns be so different that you feel like you need to style them this way? Does that signal something?
Edo Nijmeijer
  • February 19, 2020
Hi Bon,
MathFour
AIMMS Partner
  • February 19, 2020
Thanks, @Edo Nijmeijer!
I am creating something for a client so they can FAR more easily adjust styling. Thus I’m not designing around a project, I’m designing around the prospect of many projects.
If I can’t do it, that’s fine. It'll just not be available.
Edo Nijmeijer
Glad to hear you’re considering the options most relevant for the situation. Even if they’re lacking and even if the situation is still future. That is always the way forward :sunglasses:
Once again, thanks for asking here, so others benefit too.
