How to Select a Date in WebUI
  • 8 March 2021
  • 6 replies
  • 109 views
Badge
  • 9 replies
I have a String parameter for BeginDateofCalendar which takes a string of date.
I created a procedure for getting value for the above string parameter using DialogGetDate which gives me option to select a date from Calendar.
But it only working in WinUI
When i am running the procedure in a page in WebUI its running but the calendar is opening in AIMMS App, not in WebUI.
what should i do so that the calendar opens in WebUI and not in AIMMS App?
Best answer by Chris Kuip 11 March 2021, 15:50
Badge +7
Hi Roy,
Is this what you are looking for?
With kind regards,
Chris
Badge
Hi Roy,
With kind regards,
Chris
Yes I am looking for that. I saw that page earlier. But That page has no information  how to implement it.
Badge +7
Hi Roy,
To be honest, there is no direct equivalent of DialogGetDate in the WebUI. In the WebUI, it is possible to get an element in a calendar, and this calendar element can be specific up to a minute. You can convert an element to a string easily using formatString. For instance as follows:
sp_someDay := formatString("%e”, ep_someDay);
More elaborate conversions between element and string can be done using StringToTimeslot and TimeslotToString not illustrated here.
Please find enclosed an example AIMMS project for selecting(in sequence):
  1. A date
  2. A date/time
The dialogs presented in here can be found by hovering over the value of ep_someDay or ep_someMinute and selecting the small calendar icon that appears.
Please let me know if this answers your question.
With kind regards,
Chris
Hi @roy
Did Chris’s answer help you with your problem?
Thanks
Badge
Hi @roy
Thanks
Yes @Andrew.
Badge
Hi Roy,
  1. A date
  2. A date/time
With kind regards,
Chris
Thanks @Chris Kuip for the help.
