How to Select a Date in WebUI
  • March 8, 2021
  • 6 replies
  • 213 views
I have a String parameter for BeginDateofCalendar which takes a string of date.
I created a procedure for getting value for the above string parameter using DialogGetDate which gives me option to select a date from Calendar.
But it only working in WinUI
When i am running the procedure in a page in WebUI its running but the calendar is opening in AIMMS App, not in WebUI.
what should i do so that the calendar opens in WebUI and not in AIMMS App?
Best answer by Chris Kuip
Hi Roy,
To be honest, there is no direct equivalent of DialogGetDate in the WebUI. In the WebUI, it is possible to get an element in a calendar, and this calendar element can be specific up to a minute. You can convert an element to a string easily using formatString. For instance as follows:
sp_someDay := formatString("%e”, ep_someDay);
More elaborate conversions between element and string can be done using StringToTimeslot and TimeslotToString not illustrated here.
Please find enclosed an example AIMMS project for selecting(in sequence):
  1. A date
  2. A date/time
The dialogs presented in here can be found by hovering over the value of ep_someDay or ep_someMinute and selecting the small calendar icon that appears.
Please let me know if this answers your question.
With kind regards,
Chris
Chris Kuip
  • March 10, 2021
Hi Roy,
Is this what you are looking for?
With kind regards,
Chris
  • March 11, 2021
Hi Roy,
With kind regards,
Chris
Yes I am looking for that. I saw that page earlier. But That page has no information  how to implement it.
Chris Kuip
  • March 11, 2021
Hi Roy,
  1. A date
  2. A date/time
With kind regards,
Chris
Andrew
  • March 16, 2021
Hi @roy
Did Chris’s answer help you with your problem?
Thanks
  • March 16, 2021
Hi @roy
Thanks
Yes @Andrew.
  • March 16, 2021
Hi Roy,
  1. A date
  2. A date/time
With kind regards,
Chris
Thanks @Chris Kuip for the help.
